Wild card in search?
Thread begun 5/20/2013 7:14 am by sysop349733 | Last modified 5/20/2013 9:17 am by sysop349733 | 1074 views | 2 replies |
sysop349733
Is it possible to enable a wild card in a search? For example, I would like a search for First Name to be an exact match so that if a user searches for "Rob", she only gets Rob and not Robert, Roberto, Roberta, etc. However, if the user is unsure of the full first name, I would like for her to be able to search for Rob* and get all names starting with Rob.
Is that doable?
use a keyword search.
and set it to use Includes.
in the key word search settings, set the Start and End Encapsulator to use a double quote "
This way searching for:
rob
will return:
Rob, kabob, Robert, Roberto, Roberta
(If you like, you can use Begins with instead of includes)
but searching for:
"rob"
will return only Rob
sysop349733
Great! Thank you and thanks for the swift response.
