Repeating Table
Thread begun 5/19/2013 10:16 am by Paul | Last modified 5/21/2013 2:24 pm by Paul | 2187 views | 4 replies |
PaulBeta Tester
Repeating Table Issue
Im attempting to create a repeating table with CS6, only its failing to create the code in my PHP page.
To recreate; WebAssist > Database > Repeating Table
I'm selecting All records and 1 column
All i'm getting in my PHP page is a table;
<table id="repeated_table_1">
<tr>
<td>[Your Repeated Content]</td>
</tr>
</table>
and no server behavior present.
I have also closed and deleted the WinFileCache, reopened and tried again. No luck.
Any ideas?
make sure you have the latest version of Data Bridge installed. The latest version is 1.1.3. if you have a previous version installed, make sure to uninstall it from the extension manager before installing the newer one.
PaulBeta Tester
I have.
I've used instead WebAssist > Data Assist > Repeat Selection instead.
Puzzled as to why the above route failed and is still not functioning
I see, you are selecting to use 1 column, That is not the intent of the repeating table behavior.
The intent of the repeating table behavior is to create a grid layout with more than one column.
a singel column layout can be easily created using a repeat region. the repeating table is used to create a layout that uses more than 1 column.
PaulBeta Tester
lesson learned.
