get current language by php
Thread begun 5/19/2013 2:29 am by davo | Last modified 5/24/2013 8:42 am by Jason Byrnes | 1327 views | 3 replies |
davo
I need to do some changes on the website, created by webassist CMS and I need to get the current language, so I was wondering if there is some global variable (initially set in the code by CMS) so I can just use it somewhere in the code.
Thanks,
Davit
Do you mean detecting the browser language?
See this thread on stack overflow:
http://stackoverflow.com/questions/3770513/detect-browser-language-in-php
davo
Thanks for the reply,
No, I mean if the website is multilanguage, e.g. it is available in Russian and English, so how can I detect the current language, because actually it is not appeared in the url, the same url can be both in English and in Russian, so, in CMS it should check the language and then the appropriate file/layout/translation should be loaded , right ? so I need that variable to be able to write some custom if condition.
The user would need to choose which language by clicking a link for English or French or other
when they click the link, set a session variable with the chosen language and use the session to determine which language the user chose.
