Design Extender 1.1.2 has been released - Includes Inline live editing for PCMS Builder
Thread begun 5/18/2013 12:18 pm by Jason Byrnes | Last modified 8/05/2015 1:03 pm by Ray Borduin | 4837 views | 6 replies |
Design Extender 1.1.2 addresses the following Issues:
• Added Live Mode Editing to the PowerCMS installation. CMS areas can now be click edited when browsing the site when logged in as Admin. Steps for updating existing PowerCMS installations can be found here: http://www.webassist.com/community/tutorials/view_tutorial.php?tid=225
• Corrected an issue that caused a ‘Document.load() is depcreated’ console error to appear in FireFox when generating driving directions using a Google Map.
• Corrected an issue that caused Site Import to not follow page links that used fully qualified URLs.
• Corrected an issue that caused a slash / to be added after each keystroke when editing menu contents in the CSS Menu Writer user interface.
If you have a previous version oF Design Extender installed, make sure to uninstall it from the extension manager before installing this newer version.
Also the new Design Extender 1.1.2 includes SEO of Title, Description and Keyword metatags :) These can be created by selecting the appropriate metatag (the content inbetween the metatags) in your code and then select "Add Content to PowerCMS (this will automatically create database entries for Meta-Title, Meta-Description and Meta-Keywords...alternatively you can log into the PowerCMS Admin and create this content manually as long as you use Meta-Title, Meta-Description and Meta-Keywords as the content name.
DarylBeta Tester
Is it possible to add the in-line editing feature to areas that show content created using 'HTML Editor' rather than using the full 'Power CMS Builder'?
At this time,it would need to be hand coded to add this to HTML Editor. We will be working on adding this feature to an update to Data Bridge, but for now, it is only a feature of Poser CMS.
I was going to write a tutorial using Ajax etc to include inline editing to CKEditor manually (without using PowerCMS) I haven't had a chance to write the tutorial yet...but can show the code via this thread if you need it quick...I got help creating it from Ray so it all works perfectly :)
@Daryl While I write up the code in a proper tutorial...here are the "magic components" in getting Inline Editing without PowerCMS:
On the page you wish to apply the Inline feature create a php function that pulls in the element (this saves on having multiple recordsets due to having many elements on the page that are editable) Here is an example that I had adapted to also checks the php filename and uses that to filter.
<?php require_once('Connections/jpackerdb.php'); ?>
function getCMSByElement($db,$connection,$element) {
$basefile = basename ( $_SERVER['PHP_SELF'] );
mysql_select_db($db, $connection);
$query_rsCMS = "SELECT CMSContent FROM cms WHERE CMSLocale = '$basefile' AND CMSElement = '$element'";
$rsCMS = mysql_query($query_rsCMS, $connection);
$row_rsCMS = mysql_fetch_assoc($rsCMS);
mysql_free_result($rsCMS);
return $row_rsCMS["CMSContent"];
2. Next where you want to apply the inline editing to (in my example a H1 tag I used for the heading for my page:
<h1 contenteditable="true" rel="Header"><?php echo getCMSByElement($database_jpackerdb, $jpackerdb,'Header'); ?></h1>
3. then call the ckeditor.js file:
<script src="js/ckeditor/ckeditor.js"></script>
4. then the actual javascript that includes AJAX which will then pass on an update.php file (the update.php just consides of a webassist update record behaviour and I use <?php echo ($_POST["CMSElement"]); ?> for the value.
if (window.CKEDITOR) {
CKEDITOR.on("instanceCreated", function (event) {
var editor = event.editor
var element = editor.element;
var contentID = element.getAttribute("rel");
var toolbar = element.getAttribute("toolbar");
if ( element.is( 'h1', 'h2', 'h3' ) || element.getAttribute( 'id' ) == 'taglist' ) {
editor.config.toolbar = [
["Bold","Italic","Underline","Strike", "Link"]
editor.on("blur", function() {
if (this.checkDirty()) {
if (confirm("Save Changes?")) {
this.resetDirty();
var params = {
CMSElement: contentID,
body_text: this.getData()
$.ajax({
url: 'cms-update.php',
global: false,
type: "POST",
dataType: "text json",
data: params
} else {
element.innerHTML = this.oldEditorData;
editor.on("focus", function() {
this.resetDirty();
this.oldEditorData = this.getData();
</script>
Chris
Atiqur Sumon
This code is working thank you.
