Help with some insert code
Thread begun 5/17/2013 11:38 am by iainmacdonald331081 | Last modified 5/20/2013 5:55 pm by iainmacdonald331081 | 3864 views | 13 replies |
iainmacdonald331081
I have a set up that involves some insert code for a table based on a series of checkboxes, that is mixed in with some DataAssist code.
When I've used it before, the form action is another URL, with that code at the top of that page where it is executed.
But in this example, the WA form is of the form:
action="<?php echo(htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)."?".$_SERVER["QUERY_STRING"]); ?>"
ie is reloading the page, and doing the DA insert before getting to the redirect URL in the PHP code at the top of the page.
My problem is that my other insert code is executing twice, presumably once when the page first loads, and again when the form on the page is submitted. The bit of code is this, which is the last bit of PHP before the <DOCTYPE> etc:
*insert Lodge Activities into the LodgeActivities table
//sql insert string
$sql = "INSERT INTO ItineraryActivities (ItineraryID, ActivityID) VALUES ";
$ck = $_GET['ckbox'];
//loops though the profiles adding the insert string each profile row
foreach ($ck As $GetIndex => $GetValue){
if ($GetValue=='on'){
$sql .= "('{$_GET['ItineraryID']}', '$GetIndex'), ";
//trims the end ,
$sql = rtrim($sql," ,") ;
//inserts data
mysql_select_db($database_connSafari, $connSafari); mysql_query($sql); echo mysql_error();
I had thought that because my insert code is after the line with the redirect URL, it shouldn't execute on the form submit, but it looks like it is.
Hope that makes sense. I've attached a copy of the page - I'm hoping there's a fairly straightforward solution to this.
Thank you!
what is the path to the page on the server?
it looks like the redirect is set to reload the page:
$WA_redirectURL = "../itinerary_added/";
there is no if statement around the insert, so it will occur any time the page is loaded.
iainmacdonald331081
Sorry - because I've used index.php as the file names with the folders showing in the URL, the page I attached is itinerary_add_images/index.php, which redirects to itinerary_added/index.php.
Basically what I would like to happen on the page I attached is for the code:
//sql insert string
//trims the end ,
//inserts data
To only execute when it is first loaded, and not execute a second time when the form is submitted. If that can be achieved using an IF statement that would be great, although I'll need a hand with the syntax for that.
use an if statement to check the query string:
<?php if(isset($_GET['ckbox']) && $_GET['ckbox'] != "") { ?>
insert code here
<?php } ?>
and change the forms action:
action="<?php echo(htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)."?".(isset($_GET['ItineraryID'])?"ItineraryId=".$_GET['ItineraryID']:""); ?>"
iainmacdonald331081
Thanks Jason.
Can you check the action line, as its throwing up a PHP error in DW.
Have attached a revised copy in case I missed something.
CraigRBeta Tester
try adding an extra ')' on the end of the string, so that they balance out
action="<?php echo(htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)."?".(isset($_GET['ItineraryID'])?"ItineraryId=".$_GET['ItineraryID']:"")); ?>"
iainmacdonald331081
Thanks Craig - I did look for anything like that, but missed it for looking.
Unfortunately I still have the original problem, with that insert code executing twice.
iainmacdonald331081
Thanks Jason - details below.
iainmacdonald331081
Just to say the server looks like its back up now.
