Checkbox not displayed in cart.php
Thread begun 5/16/2013 9:16 am by joerg431091 | Last modified 5/16/2013 10:18 am by Jason Byrnes | 1164 views | 3 replies |
joerg431091
I have a problem with form checkboxes not displaying (for example the remove item checkbox in the cart.php).
This is probably not a problem with eCart but rather a conflict with another css stylesheet but I am hoping that someone came across the same problem and has some ideas about how to correct this.
So basically the remove item checkbox on my cart.php does not appear at all as long as I have a certain css style sheet attached to the site and does appear once I disable the style sheet. So this seams to be a conflict with anything in that stylesheet. Since I am not a pro if it comes to css stylesheets, I am having a difficult time figuring out what might cause the conflict.
Anyone has any idea about what could cause this? Any thought are appreciated.
Best,
AJ
imposible to tell what is causing the problem without being able to see it in a browser. I would need to be able to see the page and the css.
please provide a link
joerg431091
Hi Jason,
Thx for your quick response. I found the problem in the meantime.
Was of course not a eCard problem but a conflict in the css style sheet. So just in case someone would run into the same issue:
The following code in my css style sheet created the conflict with the form checkbox. After disabling the first line of the code (-webkit-appearance: none;) = the checkbox displays perfectly.
input, textarea {
-webkit-border-radius: 0;
border-radius: 0;
Best,
AJ
ok, glad to hear it is working.
