Need Help with inserting values into orders table
Thread begun 5/16/2013 7:31 am by sfranzken73972 | Last modified 5/17/2013 11:07 am by Jason Byrnes | 1635 views | 3 replies |
sfranzken73972
I added feilds to the orders table, cctype, ccnumber studentfirst etc....
but when I bind them to the store summary in orders table behavior they do not insert.
What am I doing wrong?
It is a very bad idea, and in most cases illegal to store the credit card details in your database. I don't recommend doing this.
if you are going to, you should at the very least use encryption to encrypt the credit card number and cvv values and when you are done, that info should be deleted from the DB as quickly as possible.
in the store order summary behavior, use the session bindings instead of the form bindings.
sfranzken73972
Still in Trouble
Im sorry I did not get it working and tried what you suggested.
Im sure I missed something.
Could we do a quick meeting tomorrow say any time that is good for you
so you can point me in the right direction?
This was an issue with the table settings.
In the table, the columns for the student information where set to varchar(0) meaning it was allowing 0 characters as the maximum length.
changed to varchar(50) to fix the issue.
