Access admin as super administrator
Thread begun 5/16/2013 1:10 am by CraigR | Last modified 5/16/2013 8:56 am by Jason Byrnes | 1496 views | 3 replies |
CraigRBeta Tester
Using the PowerCMS security as a starting point, I am adding a little bit of further complexity to my site.
I have modified the users_login.php page to take the user data from a members table and added a couple of new session variables to allow for the new user levels I have created.
(I have left the super administrator logic in place, and the wa_users table is still accessed for this role).
It all seems to be working OK, except when trying to log in as a super Administrator, and I can’t figure out how super administrator accesses the admin_cms home page.
The original admin_cms/index.php page has the following rule
<?php /*
if (!WA_Auth_RulePasses("Administrator")){
WA_Auth_RestrictAccess("users_login.php");
but super administrators can still access the page, even though they are not in the administrators group.
In order to allow for my additional userlevels, I created a new group called All Admin Groups which allow access to the admin home page if the userlevel is either 1 or 2. (multi group administrator or administrator)
This seems to work OK, but I cannot access the page as a super administrator using this rule
on the admin_cms login page, there is the following code:
if(isset($_SESSION['UserGroupID']) && $_SESSION['UserGroupID'] == 1) {
$_SESSION['AdminLogin'] = $GLOBALS['WAGLOBAL_Admin_Password'];
if (!session_id()) session_start();
if((((isset(
$_POST["userName"]) && $_POST["userName"]== $WAGLOBAL_Admin_Username)?$_POST["userName"]:"") != ""))     {
$_SESSION["AdminLogin"] = "".((isset($_POST["Password"]))?$_POST["Password"]:"")  ."";
$_SESSION["SuperAdminLogin"] = "".((isset($_POST["Password"]))?$_POST["Password"]:"")  ."";
this sets the AdminLogin and SuperAdminLogin if the supper admin is logging in. The supper admin doesn't get a UserGroupID though.
you can edit that to force the UserGroupID to 1 if the supper admin is logging in:
if((((isset(
$_SESSION['UserGroupID'] = "1";
CraigRBeta Tester
Great, that seems to work.
I still don't quite understand why super admin gets access to the index page when it isn't in the administrators group though !
because the AdminLogin session gets set on Super Admin login.
Since the AdminLogin session is set, the super admin is a member of both the Admin and Super Admin groups.
