Will new WA extensions work with DataAssist code prior to Dreamweaver CC upgrade
Thread begun 5/15/2013 2:20 am by YellowCircleWeb | Last modified 5/15/2013 9:18 am by Jason Byrnes | 1383 views | 1 replies |
YellowCircleWeb
I'm working on a web project for a client at the moment that makes extensive use of databases throughout. I'm using DataAssist and Dreamweaver CS6 along with Security Assist.
As the next version of Dreamweaver is removing server behaviours I'm curious to know whether I will still be able to use and edit code in that version with your extensions. I know you guys are working on an updated version of Databridge to replace the functionality that Adobe are removing from Dreamweaver, but the deadline for this project isn't until July, which is after the new DW upgrade is released.
I don't want to code things now, upgrade to DW CC and then find my client needs changes making which I can no longer do easily with Databridge. Would you advise keeping one machine running on CS6 with your current extensions or am I ok to carry on coding today and then update as normal next month to DW CC?
The updates that we will be releasing for DW CS 7 should be compatible with code from previous versions.
It may be necessary to manually delete certain lines but it should work to update pages created with the current versions.
