Display dynamic data based on category
Thread begun 5/13/2013 11:18 pm by Jorge Rivero | Last modified 5/16/2013 9:39 am by Jorge Rivero | 4037 views | 12 replies |
Jorge Rivero
I am trying to display data based on category, I have this code in MySQL
SELECT Vendors.VendorID, VendorsCategories.VendCatID, Vendors.Company, Vendors.Contact, Vendors.Phone, Vendors.Website, VendorsCategories.CatName
FROM Vendors LEFT JOIN VendorsCategories ON Vendors.intCatID = VendorsCategories.VendCatID
ORDER BY VendorsCategories.CatName , Vendors.Company ASC
I want to have a result like the following example
Category #1
vendor 1
vendor 2
vendor 3
Category #2
vendor 1
vendor 2
and so on...
I want to display the Category name once for all items in that category.
I hope someone can help me with this
Thanks in advanced
instead of using a join query for this, you would use a 2 recordsets,
the first recordset will return the categories
the second recordset nested inside the repeat region for the categories will return the items for the current category.
See the following tutorial for details:
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=12
Jorge Rivero
Thank you Jason,
I followed this tutorial yesterday, but today, since you have suggested to take a look at it, I have been following the tutorial over and over again, trying all day, and I can't get it work, my situation is a little different than this tutorial but I am doing few thing wrong for sure.
Here is an image of my page http://screencast.com/t/7eeK2rEDa (div tags and recordsets).
I can separate the categories easily because is just a repeat selection of the category recordset, here is an image of what I get back from the recordset when I do that http://screencast.com/t/KZIMggxO
Then wen I do a repeat selection of the nested div with the info from the Vendors recordset, I get this http://screencast.com/t/nWtkrzM7jNHk
Any help will be really appreciated.
Thank you.
send a copy of the page please so i can see the code.
Jorge Rivero
Thanks Jason
Here is the page attached
can you give some more details on the structure of the 2 tables please?
Jorge Rivero
What I am trying to do is display the vendors information inside of vendinfoContainer that is placed inside of vendCatContainer this last div should be repeated for each category, and display vendors information for the corresponding category inside.
I understand what you are trying to do, but i need to know more about the table structure to be able to give advice.
Jorge Rivero
I misunderstood your question.
This is the Vendor table http://screencast.com/t/fUEeXoNM it has "intCatID" that is a foreign key http://screencast.com/t/GUwsY6RG1Z7 to Vendors_Categories http://screencast.com/t/SOZiqo6X
hope this helps
Thats not giving me all the info i need.
