Map generated from a dynamic source not displaying
Thread begun 5/13/2013 10:25 am by Banksie | Last modified 5/13/2013 10:38 am by Jason Byrnes | 615 views | 1 replies |
Banksie
Hi there, I have a list of suppliers in a repeat region (generated from a Data Assist recordset), each with a post/zip code. A dynamic link from each supplier opens up a "detail" page that displays all supplier details including, I'd planned, a Google map generated from the post/zip code in the recordset. Unfortunately nothing displays!
I CAN display a map if I manually generate a page with a fixed post/zip code but can't seem to get it to work with a recordset. Removing the Google Maps code from the page enables the data to display from the recordset in the detail page as you'd expect.
Any thoughts?
Thanks in anticipation.
Gary
make sure the entire webassist/google_maps directory is uploaded to the server.
if you continue to have a problem, post a link where i can see the issue.
