WA Insert Record bindings - default should remain NULL
Thread begun 5/10/2013 7:21 am by davegw | Last modified 5/13/2013 6:57 am by davegw | 1111 views | 2 replies |
davegw
I've recently changed a Dreamweaver Insert Record SB to the WA equivalent. Some of the fields are not required and when they don't have a value, there is a condition set up on the bindings so they don't display on the page if NULL. The WA Insert Record SB binding has a conditional operator that inserts an empty string "" if nothing is posted for that field. e.g: <?php echo ((isset($_POST["case_no"]))?$_POST["case_no"]:""); ?>
Is it possible to change this to NULL without going into the code and changing it there?
In the Insert Behavior, on the bindings panel, change the Data Type to Date instead of using Text.
davegw
Thanks Jason
That worked a treat. I would never have thought of that!
Cheers
Dave
