Radio Group Multiple Update
Thread begun 5/10/2013 6:52 am by ed331947 | Last modified 6/03/2015 11:13 pm by Ray Borduin | 5186 views | 15 replies |
ed331947
I have repeating rows, at the end of which is a radio group button for a user to select only one of those records. Once submit is clicked, the database should update all of those rows of any changes made. For example, if row 2 is 'default' and user wants to choose row 6 as 'default', the database should update those records to indicate only row 6 is now selected as 'default'.
Before I add the multiple update, the selection process works just fine. However, once I add the multiple update, when row 2 shows as 'default' and the user selects row 6 to be 'default', row 2 remains selected along with row 6. Once the submit button is pressed, all records are updated to be selected.
I have attached the file and appreciate any help you can offer.
ed331947
With more experimenting, I changed the radio button section to the following:
<input type="radio" name="PublishGroup1_<?php echo $RepeatSelectionCounter_1; ?>" value="1" <?php if (!(strcmp($row_css_selected['publish'],"1"))) {echo "checked=\"checked\"";} ?> id="PublishGroup1_0_<?php echo $RepeatSelectionCounter_1; ?>" >
The buttons behave as they should, however, when clicking submit, it adds '1' to ALL the records, rather than just the one selected.
In the multiple update behavior, try changing the data type for the publish column to checkbox 1,0
ed331947
It still updates all records with '1' instead of '1' or '0'
ed331947
You can find the ftp info below. I really appreciate your help.
What is the purpose behind using the multiple update for this?
Should only one of the 3 options be allowed to be published?
I'm not sure i understand why you are using the radio group and multiple update.
ed331947
I want the end user to select one 'default' theme. I want them to have options of having more at the ready for holidays, etc., but they can only have one selected to be the default. Make sense?
ok i got you.
Multiple update is not the way to do this.
instead use 2 update behaviors.
1) the first one will update all records to set the published column to 0
in the update behavior set the key column to use the published column. Set the Key Value to 1.
on the bindings tab, set the value for the published column to 0.
2) a a radio button to the page, and use a repeat region around it.
bind the value to the css_configid column of the recordset. also set the ID to use the css_configid column from the recordset along with the radio button name so that each radio button gets a unique ID.
In the second update record behavior, set the key column to the css_configid column. Bind the key value to the radio button, on the bindings panel set the value for the published column to 1.
the idea is to reset the published column to 0, then update the selected record to 1.
ed331947
Thank you. I will give that a shot. As always, I appreciate your support!
