convertString problem
Thread begun 5/10/2013 4:54 am by Jamie | Last modified 5/10/2013 7:11 am by Jason Byrnes | 1741 views | 3 replies |
Jamie
Hey Jason
Am using this
function convertString($string) {
$retStr $string;
$retStr str_replace(array("<p>","</p>","<blockquote>","</blockquote>","<strong>","</strong>","<em>","</em>","<u>","</u>","&nbsp;"), ""$retStr);
$retStr preg_replace("/<a href=\"(.*)\">/i"" "$retStr);
$retStr preg_replace("/<img[^>]+\>/i"" "$retStr);
    return
$retStr;
combined with this
<?php echo substr(convertString($row_NewsPanelRS['NewsContent']),0,250)." ..."?>
But the problem is that if part of the content within the first 250 characters has got a link on it, then it removes all the content up to that <a> .. what am I doing wrong?
If you want to see it in action, you can see on this page As you can see from the main content, the first paragraph startes with 'After' but if you look at the Lateste News Article panel it startes with Motley which, as you can see in the main window, is a link.
Cheers
Jamie
for strtiping the links, use this instead:
$retStr = preg_replace("/\<a(.*)\>(.*)\<\/a\>/iU", "$2", $retStr);
Jamie
thanks Jason. Thats done the trick. Technically, what does yours not do that mine did to create the problem?
yours doesn't look for closing </a> tags.
