SA Access Rules Manager (In DataBridge)
Thread begun 5/09/2013 4:04 pm by Paul | Last modified 5/13/2013 7:49 am by Jason Byrnes | 1638 views | 3 replies |
PaulBeta Tester
I have users which are required to login to access functionality.
When a user logs in, the user type session variable is set according to user account type, which is either a 1 or 2
Ive been trying, without luck, to set a show/hide region region on a menu based on an access rule.
My rule simplified is this;
If the logged in users account type session = 1, then only menu options 1 through 4 are seen
If the logged in users account type session = 2, then only menu options 5 through 10 are seen
How should i set up the rule condition(s) to accomplish the above?
Thanks, Paul
it looks to me like that should work.
can you send a screen shot of the rules that you created and a copy of the login page please.
PaulBeta Tester
Screenshot as requested
you don't need the restrict if condition.
the rule as you have it configured will never work. just use the one allow if condition.
