File upload not working
Thread begun 5/09/2013 3:28 pm by Nutzo247 | Last modified 5/14/2013 11:18 pm by Nutzo247 | 4304 views | 9 replies |
Nutzo247
I'm trying to create an product page to update the database but when I create the upload for the jpeg images (both full size and thumbnail) it doesn't work. Also I want to update the database with the filename uploaded but I don't know with variable I should use.
Please help
Send a copy of the page so i can see the code.
The File Upload server behavior will create a Binding Group named WA Uploaded Files (<File Field Name>)
In theWA Uploaded Files (<File Field Name>) binding group there will be bindings that have the Upload path for the large image at the beginning of the names, and another set of with the path for the thumbnail image at the beginning of the name.
in both sections there is a binding for Server file name.
Use those bindings in the insert behavior.
Nutzo247
here is the file,
but I don't know which binding is correct:
-Client File Name
-Server File Name
-Server Simple File Name
1) For File Upload to work, the forms encoding type must be set to multipart/form-data.
In the tag selector, select the form tag and change the encoding type to multipart/form-data in the property inspector.
2) You are using the Dreamweaver Insert behavior. The DW INsert Behzavior is limited in only being able to use form data bidnings, it cannot access the DFP Bindings that are created, you should use the data assist insert record behavior instead.
3) The File upload code happens after the insert code, it should come before the insert code.
4)
Originally Said By: Nutzo247
  here is the file,
-Client File Name
-Server File Name
The Server File Name binding is the correct one to use. That binding will contain the files name that is created on the server.
Nutzo247
This post has been deleted.
Nutzo247
Checkbox not updating in to SQL
in the database set the datatype for the column to int and in the Insert behavior, set the Data type for the column to Checkbox 1,0
Nutzo247
I've done that.. the slight difference is that the database datatype is tinyint(1)... Anything else?
Nutzo247
thanks for the offer... but it started working after I corrected the username and datestamp.
Thanks Again.
