gallery no longer popping up
Thread begun 5/09/2013 7:31 am by Jamie | Last modified 5/09/2013 8:27 am by Jason Byrnes | 1372 views | 3 replies |
Jamie
Hey Jason
Just wondering what may have happened to this site as the ribbon gallery at the bottom of each page is no longer pops up the larger image
http://www.rallyforheroes.com/
Many thanks
Jamie
using fire bug, i see a number of javascriot errors in the error console:
TypeError: $(...).cycle is not a function
http://ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js
Line 3
is the first one, it is probably causing the other errors, and causing the ligthbox script to fail.
Jamie
as ever Jason, you are absolutely right! works fine now. thanks
your reply brings up another question as I dont know how to use Firebug to trouble shoot in that way...would you have a good tutorial you could recommend on its use etc?
I dont have a tutorial, no.
there are a number of them available through google though. heres one i found:
http://www-10.lotus.com/ldd/lqwiki.nsf/dx/08282008054536PMWEBTJ3.htm
