Replacing period decimal with a comma decimal
Thread begun 5/08/2013 10:17 am by Roxana | Last modified 5/10/2013 10:42 am by Roxana | 6142 views | 11 replies |
Roxana
Hi, I have been working on this for a while and came up with this code so far:
$number = $row_rspricetable['price'];
$row_rspricetable['price'] = number_format($number, 2, ',', '.');
This successfully replaces the period of the first record with a comma, but all following values keep the period. I tried with if-statement, while loops and foreach statements, but could just not get it to work.
This is the link to one of the product pages: http://www.segufix.com/detail_en.php?recordID=13
Would anyone be able to help me out?
within the repeat region, where you show the number, use the following:
<?php echo(number_format($row_rspricetable['price'], 2, ',', '.')); ?>
Roxana
Thank you, Jason. That worked. I had also just tried cramming my code into the repeating region. It also worked, but your solution is much more concise :)
Roxana
Trying to use this code on shop site
Hi Jason,
I changed the code again, so I would get a decimal point for English and a decimal comma for German:
<?php $number = $row_rspricetable['price'];
if ( $_SESSION['languageID'] == "1" ) {
And it works, as you can see here: detail.php?recordID=53
I would like to do the same on the shop site, but the code did not work for there. I am guessing, because the number format is already defined. I tried deleting that code, but with that the page broke.
function WA_eCart_GetGroupDecimalChars($numDisplay) {
$theDec = substr(strval(99/10), 1, 1);
$theDecimal = "";
$theComma = "";
if ($numDisplay == 0 || $numDisplay == 2) {
$theDecimal = ".";
if ($numDisplay == 0) {
$theComma = ",";
else {
$theDecimal = ",";
if ($numDisplay == 1) {
$theComma = ".";
return array($theDec, $theComma, $theDecimal);
function WA_eCart_DisplayMoney($theObject, $theAmount) {
$decInfo = WA_eCart_GetGroupDecimalChars($theObject->NumberDisplay);
return WA_eCart_MaskWeightMoney($theAmount, $theObject->CurrencyPrefix, $theObject->CurrencyAlign, $decInfo[1], $decInfo[2], $theObject->ForceDecimalsC, $theObject->DecimalPlacesC);
On the shop site I am dealing with six languages. I would like to use decimal point for English and Spanish, decimal comma for all other languages.
Can this be achieved? It might be a nice feature for eCart.
assuming that English and Spanish use $_SESSION['languageID'] == 1 and $_SESSION['languageID'] == 2, then you could use the following code to change the number format that the cart will use:
if(isset($_SESSION['languageID']) && ($_SESSION['languageID'] == "1" || $_SESSION['languageID'] == "2")) {
$yourCartName->NumberDisplay 0;
} else {
$yourCartName->NumberDisplay 1;
this code should come just after the GetContent line on the cart page.
Roxana
Thanks Jason,
The correct number format pops up for a split second and then goes back to comma decimal.
I think the problem lies in this coder:
function showprice() {
var fm = document.segufix_1_ATC_<?php echo $row_DetailRS1["product_id"]; ?>;
var selectedversion = fm.SelectVersion.options[document.segufix_1_ATC_<?php echo $row_DetailRS1["product_id"]; ?>.SelectVersion.selectedIndex].text;
var selectedsize = fm.SelectSize.options[document.segufix_1_ATC_<?php echo $row_DetailRS1["product_id"]; ?>.SelectSize.selectedIndex].text;
var versionset = fm.SelectVersion.value;
var sizeset = fm.SelectSize.value;
var priceset = js_array[(sizeset+0+versionset)].toFixed(2);
priceset = priceset.replace(".", ",");
var pznset = js_array2[(sizeset+0+versionset)];
var itemnolongset = js_array3[(sizeset+0+versionset)];
document.getElementById('pricelabel').innerHTML=' € '+priceset;
document.getElementById('pznlabel').innerHTML=pznset;
document.getElementById('itemnolonglabel').innerHTML=itemnolongset;
I tried deleting just the line with the "replace", but then the decimals are dots for all languages.
try putting the code i provided just before the doctype tag.
Roxana
Ok, the code works on the cart page and the catalogue page. It is now after the getContent line.
But it does not work on the detail page. Even when I place it just before the doctype tag, or right before the price itself.
I think the problem is, that the price on the detail page is updated, when the customer makes a size or version selection. The price pops up very shortly with the decimal dot and actually the wrong prize (the prize for size M) and then changes to the prize that is first in the database for that product (size XS) with a decimal comma.
There is a mini cart on the detail page however, and there the code works.
Sorry for making it so complicated, but if you want to have a look: [url]http://www.segufixshop.eu/detail.php?recordID=69[/code]
Roxana
OK
