Cannot add a new MySql database
Thread begun 5/08/2013 2:40 am by john70964 | Last modified 5/11/2013 9:17 am by john70964 | 6505 views | 8 replies |
john70964
Hello
I realise the error I am getting has very little to do with Webassist but am hoping someone may have some helpful information perhaps "been here before"!
I am using xampp with DW CS6 on XP
I am also using Navicat and have 3 sites with mysql databases all working OK on my local machine.
I decided to create another mysql database but am having difficulties.
In Navicat I went to create a new database and entered a name but received an error message
1144 Access denied for user 'root'@'localhost' to database 'Mydatabase'
I selected Manage Users and received the error
1142 SELECT command denied to use 'root'@'localhost' for table 'user' as far as I can see there is no table called user.
If I right click existing and working database and the select Manage users I get the error
I put the question to Navicat and they came back with the following suggestions but I cannot find where to run their suggestions.
GRANT ALL PRIVILEGES ON *.* TO 'YourUserName'@'%' IDENTIFIED BY "YourPassword";
or
GRANT ALL PRIVILEGES ON *.* TO 'YourUserName'@'YourIP' IDENTIFIED BY "YourPassword";
I cannot open phpMyAdmin as I get errors.
Sorry if placing a mysql question here is out of order.
Thank You
John
In Navicat, there should be a SQL Query window where you can run the GRANT Privlages SQL Command
What are the errors you get opening phpMyAdmin?
john70964
Thanks for your help Jason
The error when trying to open phpMyAdim is:
phpMyAdmin tried to connect to the MySQL server, and the server rejected the connection. You should check the host, username and password in your configuration and make sure that they correspond to the information given by the administrator of the MySQL server.
In Navicat the is a"tool" called Console
Navicat suggested I ran GRANT ALL PRIVILEGES ON *.* TO 'YourUserName'@'YourIP' IDENTIFIED BY "YourPassword"; in a command line I have carried this out but it produces an error.
I am attaching a picture of the command line perhaps you can see where I am going wrong.
Regards
John
launching the command line using:
mysql -u localhost
you are leaving the username blank.
the blank username does not have privileges for running the command grant command. hence the returned error
access denied for user ''@'localhost'
you have not logged in, so there is no user.
john70964
Thank you so much for that Jason
I did not realise that the username went where the little dot was placed, I thought that may have meant "here"!
After inserting the username the script did not complain with an error so I guess that was OK.
It doesnt seem to have changed very much as far as Navicat is concerned, I still cant create a new database in that, however I can now open phpMyAdmin so thats real progress!
I thank you again!
can you create the table in php my admin?
then edit it in navicat?
john70964
Seems not at the moment
in phpMyadmin under the database tab and under the Create New Database link there is a X and No Privileges sign.
in phpMyAdmin, there should be a User Tab
listed in the users section is the root / localhost user, make sure that user is set to have al privileges.
this thread al stack overflow has some details on how to reset the root users privileges:
http://stackoverflow.com/questions/1709078/how-can-i-restore-the-mysql-root-users-full-privileges
if all else fails, export your databases using the export tab in phpMyAdmin, uninstall xampp and do a fresh download install of it. then re import the databases.
john70964
Thanks Jason
I think I will not have to use the "last resort" but it was good to hear your ideas on If all else fails.
I dont really understand what went amiss but after reading it seemed like thousands of forums, someone suggested using user and no password to log in from then onward it all came together.
I also had to change the connection properties to"user" in phpmyadmin and in Navicat.
The user tab called privileges in phpmyadmin would not appear until I used the "user" login
I have no idea why this should be I definitly havent used "user" previously.
There you have it. I thank you for taking the time to assist me.
Regards
John
