adding authorize.net declined details for user
Thread begun 5/07/2013 4:05 pm by steve204795 | Last modified 5/08/2013 8:18 am by Jason Byrnes | 1707 views | 3 replies |
steve204795
some users are getting the checkout_failure page .. and there's no details of why - just the generic msg that either the card or address is wrong ... can i add more detail of what they were declined for?
Go to the bindings panel and click the plus button.
If you are using the Authorize.net AIM Method, select eCart -> Checkout -> Local Checkout response. From the gateway list select Autorize.net AIM
If you are using the SIM Method, select eCart -> Checkout -> Checkout Form Response. From the gateway list select Autorize.net Post.
This will add a binding group to the bindings panel that you can use to show the error message, or error number and other details.
steve204795
Hi Jason .. the bindings helped .. turns out my client isn't requiring the CVV code of their users .. can i pass an ignore CVV value to authorize.net or do i need to configure that on my authorize.net account?
I'm pretty sure that would need to be set on your account, not in the code.
