DA Sort keeps adding parameters to query
Thread begun 5/07/2013 11:29 am by dan361748 | Last modified 5/08/2013 11:12 am by dan361748 | 2992 views | 6 replies |
dan361748
Hi - I'm trying to use the Sort behaviour with DataBridge.
After implementing it, the results I was getting seemed really weird, so I echoed the query and my query strings are looking like this:
SELECT activity_id, activity_type, activity_ip, activity_date, activity_username FROM activity_log_admin ORDER BY activity_type ASC, activity_ip DESC, activity_date DESC, activity_username DESC
So as you can see each click on the column or toggle of order adds to the query, giving strange results. How do I prevent this so each click on the column heading sorts ONLY by that order (or desc/asc depending on subsequent clicks of the same link)?
Dan
dan361748
Thanks - posting reply.
Originally Said By: dan361748
dan361748
Private
in the data assist sort server behavior, you have the activity_type, activity_ip,activity_date, and activity_username columns selected.
if you only want to sort on the column that is clicked on, remove those other column from the sort lirt, then click the lightning bolt icon and select the sort URL variable
dan361748
Thanks Jason - that's got it. Dumb mistake!
Dan
