Databridge Dynamic Dropdowns not inserting value
Thread begun 5/07/2013 2:17 am by Rune Brynestad | Last modified 5/08/2013 12:35 am by Rune Brynestad | 2818 views | 6 replies |
Rune Brynestad
The child dropdown is not submitting its value into the database
I have attached the record insert page
Any thoughts please?
Thanks in advice
Regards
Rune
i dont see an obvious problem in the code. I'll need to troubleshoot directly, see the private message section.
Rune Brynestad
See the private message section
at line 317, it sets the CHILD ID column, it was using a column name that does not exist in the undergrupper table:
echo "WAJA[".$n."][".$m."][0] = "."'".WA_DD_Replace($row_WADAMenuUnderkategori["id"])."'".";\n";
I changed that to:
echo "WAJA[".$n."][".$m."][0] = "."'".WA_DD_Replace($row_WADAMenuUnderkategori["Gruppeid"])."'".";\n";
to correct the problem.
Rune Brynestad
Perfect! Thanks!
Could you please have a look at my update page too ? The target list is not populated on page load.
I have applyed the Dynamic Drop Down Populate List from array and Set Selected in List behaviors to the onLoad event of the body tag. But I have also applyed a framework builder theme to the page, so it have been destroyed.
I'm attaching my update page.
Thanks in advice.
Regards
Rune
since your using a template, you cant add script behaviors to the body onload event.
add the behaivors for set selected and populate form an array to the onblur event of a div or the form tag, then copy the code to a script tag near the bottom of the page so it will be executed after the page loads.
Rune Brynestad
Perfect!
Thanks again.
Regards
Rune
