Forms - File attachment
Thread begun 5/06/2013 11:52 am by rob294118 | Last modified 5/07/2013 9:01 am by Jason Byrnes | 4667 views | 15 replies |
rob294118
I created a form with 3 file attachment fields but they are not showing up in my email. What am I missing?
Thanks.
send a copy of the form file and the webassist/email folder so i can see the code.
rob294118
Here you go.
Thanks.
in the waue_becomeamodel_1.php page, you have not added any attachments
go to the attachments section of the Universal Email behavior and add the files fields as attachments.
rob294118
The "photo" fields are file attachments.
They are file file fields in the form, but you have not configured the attachments section of universal email to uyse them to attach the files to the email.
in the in the waue_becomeamodel_1.php page you sent the Attachment Entries section is empty.
you need to edit the universal email server behavior.
click the paper clip icon to manage email attachments.
rob294118
I did this but it still doesn't work. I attached the new files.
1) You have only 1 file upload behavior, if you are going to save the files to the server, you need an upload behavior for each file field.
2) In the attachments section, you have bound to the file field form elements, instead, you need to use the server file name and server file directory bindings created by the upload behavior.
on the bindings panel, there will be a binding group for each upload behavior named:
"WA Uploaded Files (<file field name>)"
for each attachment, select the Server file directory binding from that binding group, then copy the binding code and select the Server file name binding. Paste the server file directory code in front of the server file name code.
NOTE: if you don't need to save the files to the server, you can use the submitted file option instead, but this only works if you don't have the file upload behaviors
rob294118
Current Files
I don't need to save the files to the server. It's for people to be able to email a file. I'm not sure what to do.
So don't include the upload file server behaviors in the page, you will need to delete the one that is already applied.
in the attachments section, select the submitted file option and select the file field.
