JSON support
Thread begun 5/06/2013 11:30 am by alnico431299 | Last modified 5/08/2013 6:54 am by mrs | 997 views | 2 replies |
alnico431299
JSON support
I use JSON extensively for my projects.
I use jsRender and jsViews to consume the JSON on the client (makes maintenance much easier and is much leaner than building the pages on the server).
When using a DW recordset...I have to comment out the fetch line (this unfortunately breaks the widget).
I then insert a few lines of code to generate the array and then encode it as JSON (no problem). I also generate hierarchical JSON as well.
Since, Adobe is removing the db functionality from CS7...I am guessing you will build your own tools...thus a perfect time to build something full featured.
Note: I am only interested in Data Assist supporting this.
Thanks,
Brent
Thanks for the feedback, i have logged a feature request in our system to have this considered for the future.
mrs
Ooo yes! I completely agree with Brent on this... JSON support would be an excellent addition. I have already requested this on a wish list myself, and I suspect that once people realise what can be achieved with JSON especially in mobile apps, then I suspect that take up of your extensions will be greater than it currently is... which I assume to be pretty good, after all, you'd be mad not use stuff this good!
