Changing the return URL when deleting a record
Thread began 5/04/2013 7:02 am by iainmacdonald331081 | Last modified 5/04/2013 7:46 am by iainmacdonald331081 | 491 views | 2 replies |
iainmacdonald331081
Changing the Redirect URL when deleting a record
I have an example which is slightly different to the regular situation, where a record would be deleted, and return to the the same page that lists the results.
The page I have is a details page, but the delete button is deleting a record in a joined table. The deletion is working, but I can't get it to redirect to the URL with the Itinerary ID.
So, for example, if the URL is:
http://www.goodsafariguide.net/itinerary_details/index_lodge5.php?ItineraryID=247
I have a look up table that pulls through Lodges that are part of the Itinerary. So I'm trying to get it to:
1. Delete a Lodge associated with the itinerary.
2. Return to the URL for the Itinerary.
By default the redirect URL line is:
$WA_redirectURL = "index_lodge5.php?ItineraryID=".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"") ."";
But the DeleteRecordID is the LodgeID, not the ItineraryID.
So I've been trying to change it, I would have thought it should be something like:
$WA_redirectURL = "index_lodge5.php?ItineraryID=".$row_WADAItinerary_Lodges['ItineraryID'] ."";
But it keeps redirecting to:
rather than
Hope that makes sense - I'm sure this must be something simple enough, but I can't for the life of me get it.
I've attached a copy of the page for reference.
Thanks.
index_lodge5.zip
CraigRBeta Tester
Try storing the itineraryid from the recordset in a hidden field in your form,
then use the post value of the field in the redirect
"index_lodge5.php?ItineraryID=".((isset($_POST["hidden field"]))?$_POST["hidden field"]:"")
iainmacdonald331081
Thank you so much Craig - its a few hours since I started looking at this, and had I thought got done the harder parts, ie adding my lookup table, the little form to add a lodge, with a drop down looking up all the lodges, adding the associated lodges to the itinerary page, and getting it to delete the right thing. But I couldn't for the life of me get that Redirect URL changed.
But that all looks like its working now with the hidden field:
<input type="hidden" name="hiddenfield" id="hiddenfield" value="<?php echo($_GET['ItineraryID']); ?>" />
And the Redirect line changed to:
$WA_redirectURL = "index_lodge4.php?ItineraryID=".((isset($_POST["hiddenfield"]))?$_POST["hiddenfield"]:"");
