Checking for unqiue database values on more than 1 field
I'm trying to use server validation to check for a unique value in the database. The value I am checking against is a company name, but I also need to check against the postcode field too. Is there a way to use validation toolkit to check against more than one database column/form field before inserting a record?
I've attached a copy of the file I am working with.
