How and WHERE to code to make a live link display in a results column?
Thread begun 5/03/2013 4:10 pm by beaded | Last modified 5/04/2013 1:48 am by CraigR | 1701 views | 3 replies |
beaded
I've checked other forum questions. Some are similar ( http://www.webassist.com/forums/posts.php?id=9501), but I just can't get it. As you can see I'm struggling with a number of things —table formatting for one. But I'll work on finessing format later.
The very last column on the right should have a live link. What do I need for each song entry in the link column of the MySQL table, and EXACTLY where do I place the anchor tags in what section of the PHP code?
Thanks.
CraigRBeta Tester
On line 155, try changing
<?php echo $row_Recordset1['link']; ?>
to
<a href="Live Link"><?php echo $row_Recordset1['link']; ?></a>
beaded
Thank you. Wonderful! I promise to do some learning on my own when less pressured.
Well, that made the result a link, but —at least in the way I have things configured— I had to put the echo inside the quote of the href tag:
<a href="<?php echo $row_Recordset1['link']; ?>"><?php echo $row_Recordset1['link']; ?></a>
Maybe the second echo (the original) is unnecessary now. I'll experiment. But it works as above. In my table data, it works if I only use the relative link starting with a / ("/").
CraigRBeta Tester
Your code will have the effect of adding the same text to the link as the link itself, this is fine if thats what you want to display
Not sure if it helps, but take a look here to see the anatomy of a link...
http://www.polr.co.uk/online-marketing/index.php/the-anatomy-of-a-link-good-to-go/
