Blog
Thread begun 5/03/2013 12:17 pm by rob294118 | Last modified 5/06/2013 10:04 am by Jason Byrnes | 2907 views | 5 replies |
rob294118
Blog
Is it possible to have an interactive blog on my a website designed with Design Extender? I don't want a Wprdpress website.
Power CMS Builder can be used to create a blog using the template concept.
see the following tutorial
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=28
rob294118
Is there a Wizard in the works for blogs? It would be a great tool?
Thanks for the info.
A blog is quite a bit more complicated than something a wizard would be able to create.
login for the admin, insert / update and navigation to start with...
more than a simple wizard would be able to accomplish.
rob294118
Interactive Blog
Is there a tutorial that teaches an Interactive Blog where people can leave comments?
No, there is not a tutorial for this.
you would need to create a new table for comments:
comments
commentID - Priamry key
commentBlogID - ID of the blog being commented on
commentText
in the tutorial i linked to, the blog detail page uses a URL Variable to load the blog article:
<a href="blog-details.php?ID=<?php echo $row_BlogRS['ContentPageSetOrder']; ?>">
the ID Url variable can be used to populate hidden form element in the comments form.
then use an insert record behavior to insert the comments.
