html editor greyed out in ie10
Thread begun 5/01/2013 12:06 pm by CraigR | Last modified 5/03/2013 10:07 pm by CraigR | 2841 views | 2 replies |
CraigRBeta Tester
My client just reported that a form containing an html editor is greyed out in ie10, working fine otherwise. Anyone aware of this problem ?
What version of CKEditor is being used?
if you use Data Bridge 1.1.3 to add HTML Editor to a site, it will add version 4 which works in IE 10.
you may want to upgrade the CKEditor files manually, see this thread for details:
http://www.webassist.com/forums/posts.php?id=30629
CraigRBeta Tester
Its a year or so since the site was installed, so it looks like a version issue.
I will look at replacing the Ckeditor files manually.
*update*
Carried out the manual update as outlined in the link
Tested and working in IE10
Haven't checked on kfm as the instance in question doesn;t use it.
Thanks again
