form quit working
Thread begun 5/01/2013 8:16 am by tkendrickmail32213 | Last modified 5/01/2013 10:50 am by Jason Byrnes | 2335 views | 5 replies |
tkendrickmail32213
form quit working
I removed a required field on https://www.surfacespecialistssystems.com/franchise_services/form-shower-pan-measure.php and the form quit working. It also no longer redirects to its confirmation page. This page requires a username and password, which is on the attachment.
if you remove a field, you need to edit the server validation server behavior to remove the validation for that field.
tkendrickmail32213
I only removed the validation, not the field itself. I did this to a similar form and it did not quit functioning as this one did.
well, your initial message said you removed the field,,,
tkendrickmail32213
see private message
the submit button has been renamed
The trigger for universal email at line 38:
if ((isset($_POST["SimpleContact_submit"]) || isset($_POST["SimpleContact_submit_x"]))) {
is looking for a submit button or image form element named:
however the submit button on your form has had it's name changed to SSPan_submit:
<input class="formButton" name="SSPan_submit" type="submit" id="SSPan_submit" value="Submit & Continue" onClick="clearAllServerErrors('SSPan_SurfaceSpecialists_ShowerPanMeasurement')" tabindex="19">
if you change the submit button name, you will need to edit the Universal Email behavior to reset the trigger.
