PowerGallery Arrows
Thread begun 5/01/2013 6:16 am by rob294118 | Last modified 5/02/2013 7:25 am by Jason Byrnes | 4798 views | 15 replies |
rob294118
PowerGallery Arrows
The arrows at the bottom of my PowerGallery do not advance the photos. I have to use the Next / Prev buttons. Link: http://www.lindseyhiggins.com/gallery.php
I'm also trying to use the Slideshow Wide for my home page and I get an error: Fatal error: Call to undefined function getCachedResizedImageHTML() in /homepages/20/d184490718/htdocs/LindseyHiggins/PowerGallery/galleries/slideshow_wide/index.php on line 53
The Arrows on the bottom are not supposed to change the Large image that is displayed.
the arrows on the bottom are to advance through the thumbnails. The gallery in your link has 19 images, it only shows 10 thumbnails at a time. to see the additional thumbnails, use the arrows at the bottom
To change the large image, either click a thumbnail or use the next / previous arrows at the top.
for the other gallery, I'll need to troubleshoot directly, see the private message section.
rob294118
rob294118
Any ideas?
rob294118
I know... it doesn't work.
"the arrows on the bottom are to advance through the thumbnails. The gallery in your link has 19 images, it only shows 10 thumbnails at a time. to see the additional thumbnails, use the arrows at the bottom"
It does for me, what browser are you using?
rob294118
Firefox
rob294118
It works in Explorer. Not sure why it doesn't in Firefox.
I updated the mootools files to fix the issues with the thumbnail, the issue with the error message on the test page is because you have a Install of power gallery 1.0.0 that has an incomplete upgrade to power gallery 1.2.2.
Download the Power Gallery 1.2.2 files from the download center and follow the readme file instructions for installing the update.
Better yet would be to upgrade to Power Gallery which has better support for newer browsers like IE 10
If you upgrade form v1 to v2, it;s a good idea to make a back up of the database first.
rob294118
I have PowerGallery 2 but that version only allows me 2 installs right?
Thank you.
