Cannot modify header information - headers already sent by
Thread begun 4/30/2013 8:36 pm by JBWebWorks | Last modified 5/01/2013 9:35 am by JBWebWorks | 1584 views | 2 replies |
JBWebWorks
I know this is somewhat common, but can't seem to figure it out from other threads.
Error message --- Cannot modify header information - headers already sent by (output started at /home/content/15/8359915/html/registeredUsers_Registration.php:61) in /home/content/15/8359915/html/registeredUsers_Registration.php on line 92
Here is my code
<?php require_once('Connections/conncoressentinc.php'); ?>
require_once("WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
if (!function_exists("GetSQLValueString")) {
function
GetSQLValueString($theValue$theType$theDefinedValue ""$theNotDefinedValue ""
  if (
PHP_VERSION 6) {
$theValue get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch (
$theType) {
    case
"text":
$theValue = ($theValue != "") ? "'" $theValue "'" "NULL";
      break;
    case
"long":
    case
"int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case
"double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case
"date":
      break;
    case
"defined":
$theValue = ($theValue != "") ? $theDefinedValue $theNotDefinedValue;
      break;
  return
$theValue;
$colname_rs_users "-1";
if (isset(
$_POST['userEmail'])) {
$colname_rs_users = ($_POST['userEmail']);
mysql_select_db($database_conncoressentinc$conncoressentinc);
$query_rs_users sprintf("SELECT * FROM registeredUsers WHERE userEmail = %s"GetSQLValueString($colname_rs_users"text"));
$rs_users mysql_query($query_rs_users$conncoressentinc) or die(mysql_error());
$row_rs_users mysql_fetch_assoc($rs_users);
$totalRows_rs_users mysql_num_rows($rs_users);
if (isset($_POST["Register"]))  {
$WAFV_Redirect "registeredUsers_Registration.php";
$_SESSION['WAVT_registeredUsersRegistration_Errors'] = "";
  if (
$WAFV_Redirect == "")  {
$WAFV_Redirect $_SERVER["PHP_SELF"];
$WAFV_Errors "";
$WAFV_Errors .= WAValidateNM($totalRows_rs_users "",-1,0,"",",.",true,1);
  if (
$WAFV_Errors != "")  {
PostResult($WAFV_Redirect,$WAFV_Errors,"registeredUsersRegistration");
$editFormAction
$_SERVER['PHP_SELF'];
if (isset(
$_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" htmlentities($_SERVER['QUERY_STRING']);
if ((isset(
$_POST["MM_insert"])) && ($_POST["MM_insert"] == "WAATKRegistrationForm")) {
$insertSQL sprintf("INSERT INTO registeredUsers (company_name, first_name, last_name, job_title, address1, address2, country, city, `state`, zip, userEmail, userPassword, phone, phone_extension) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s)",
GetSQLValueString($_POST['company_name'], "text"),
GetSQLValueString($_POST['first_name'], "text"),
GetSQLValueString($_POST['last_name'], "text"),
GetSQLValueString($_POST['job_title'], "text"),
GetSQLValueString($_POST['address1'], "text"),
GetSQLValueString($_POST['address2'], "text"),
GetSQLValueString($_POST['country'], "text"),
GetSQLValueString($_POST['city'], "text"),
GetSQLValueString($_POST['state'], "text"),
GetSQLValueString($_POST['zip'], "text"),
GetSQLValueString($_POST['userEmail'], "text"),
GetSQLValueString($_POST['userPassword'], "text"),
GetSQLValueString($_POST['phone'], "text"),
GetSQLValueString($_POST['phone_extension'], "text"));
$Result1 mysql_query($insertSQL$conncoressentinc) or die(mysql_error());
$insertGoTo "registeredUsers_LogIn.php";
  if (isset(
$insertGoTo .= (strpos($insertGoTo'?')) ? "&" "?";
$insertGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s"$insertGoTo));
CraigRBeta Tester
It looks like you have some trailing spaces after the closing php tag on line 60
JBWebWorks
Thanks CraigR,
that was what it was; i thought that i had removed all white spaces, but i guess i missed some.
