Text is correct in database but HTML does not show it on page using HTML Editor?
Thread begun 4/30/2013 1:37 am by Mark | Last modified 4/30/2013 11:44 am by Jason Byrnes | 3643 views | 9 replies |
MarkBeta Tester
Hi, just as heading really.
Using PHP, mysql database. Have an admin backend. Using HTML editir from bridge. Text is okay in database using the TEXT field and not BLOB. But when I go to the admin php page to alter the text, the editor shows, but there is no text showing - even though it is in the database and shows on the public page? Can anyone help please? Thanks Mark
send a copy of the update page please.
MarkBeta Tester
Message sent privately
Please attach a copy of the update php page so i can look at the code.
MarkBeta Tester
thanks
sent privately
MarkBeta Tester
private message
the problem was caused by the left quotes used in the content, for example:
"London’s"
I corrected the problem by changing the character set used by the connection and the update page.
in the connections/tt_conn.php page, i added the following code:
mysql_set_charset('utf8',$tt_conn);
on the update page, i changed the charset meta tag to use the utf8 character set:
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
MarkBeta Tester
thanks
No worries
