php / dynamic menu error
Thread begun 8/13/2009 6:35 am by muddysmurf | Last modified 8/14/2009 10:14 am by Jason Byrnes | 2562 views | 4 replies |
muddysmurf
Could you guys tell me what's going on with this? I know there is an extra ../ in front of Connections, because I was playing around with it. I thought it might be that it just didn't have enough of the "../" in front to connect, but that wasn't the case. My database was working until I added my dynamic menu on the left.
I had to change my database name/ connection name so I could upload it, and then fixed my pages. I tried renaming my database name inside the menu.php file, but it still doesn't work, and gives me these errors:
Warning: require_once(../../../Connections/feelthebeat.php) [function.require-once]: failed to open stream: No such file or directory in D:\Hosting\3270472\html\###\CSSMenuWriter\cssmw\menu.php on line 23
Fatal error: require_once() [function.require]: Failed opening required '../../../Connections/feelthebeat.php' (include_path='.;C:\php5\pear') in D:\Hosting\3270472\html\###\CSSMenuWriter\cssmw\menu.php on line 23
It definitely has something to do with the connections portion in my menu.php, but I'm just not sure what else to do after changing the name of the connection to match what I have now.
After the problems I had trying to get the database up and running on a godaddy windows server(not my choice), I'm tired of looking at the site. I've never had this much trouble trying to set up a site with php on a host server.
muddysmurf
Does Anybody Know?
Do you have a link where I could see the error?
it looks the require_once for the connection is set to go back three directories:
It may only need to go bak one:
or two:
muddysmurf
Sure, I forgot to add it,
index.php
When I go to the menu.php page direectly:
menu.php
I see the error is:
Warning: require_once(../../../../../Connections/feelthebeat.php) [function.require-once]: failed to open stream:
The require once line is set to go down five directories:
it only needs to go down three directories:
