Product admin site: updating option (multiple update) not working
Thread begun 4/29/2013 5:34 am by rikaG_510 | Last modified 5/02/2013 11:36 pm by rikaG_510 | 1896 views | 4 replies |
rikaG_510
Hi Jason,
I'm making a simple product admin site using DataAssist so my client can edit the product info without my help.
Everything is working except updating product option info to Options table.
All the products info are stored in 'Products' table, and option info is stored in 'Options' table in my database.
Options data is pulled by ProductID and it's successfully showing on Update page.
But I must be doing something wrong with Multiple Update Server Behavior setting, Options data is not being sent to the database (product info is sent fine).
No error message after adding this:
error_reporting(E_ALL);
It'll be a great help if you could look at my codes.
What am I missing?
Attached text file is for the Update.php page.
Thank you for your help in advance.
I don't see anything obvious in the code, I'll need to troubleshoot directly, see the private message section.
rikaG_510
I found one thing missing in the code. OptionID wasn't binded in rsOptions recordset.
After I fixed this, when I update the record the option info is over-written with OptionID number.
And still cannot make any change to option info.
i corrected the problem by updating line 139:
$WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("WADA_RepeatID_OptionID", $WA_multipleUpdateCounter)  ."";
$WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("ProductOption", $WA_multipleUpdateCounter)  ."";
rikaG_510
Hi Jason,
Everything is perfectly working now.
Thank you so much!
