Adding subcategories to Powerstore
Thread begun 8/13/2009 6:28 am by gwh362692 | Last modified 8/19/2009 2:41 pm by Jason Byrnes | 2134 views | 3 replies |
gwh362692
In order to add subcategories to the Powerstore, I'm going through the steps that are outlined in the following thread:
showthread.php?t=2785&highlight=modify+product+insert+update+pages
I've created the pages using dataAssist. After the pages were created by the wizard, I found that I had to do some further work on the insert page by adding a server behaviour to the categories dropdown menu in order to populate it with data from the poductcategories table. I found though that when I tested in a browser, I was getting an error showing up in the entries in the drop-down menu, eg.
Notice: Undefined index: in /Applications/MAMP/htdocs/new_site/Admin/Subcats_Insert.php on line 174 > Men's Clothing
Notice: Undefined index: in /Applications/MAMP/htdocs/new_site/Admin/Subcats_Insert.php on line 174 > Women's Clothing
Does anyone know what might be causing these? I have attached the code.
Appreciate further help with all this.
In the file you attached, line 174 is:
$rows = mysql_num_rows($rstProductCategories);
this code is setting a variable named rows to the number of rows contained in the rstProductCategories recordset. I don't see how this code could produce the error you are reporting.
Could you post a link to where we could see the error? Maybe compress the original php file in zip archive and attach that?
gwh362692
I've uploaded the php file as suggested.
Thanks for looking into it.
I have created a support ticket to look into this issue.
To view and update your ticket, log into your support history at:
