Strange isue with file upload
Thread begun 4/26/2013 12:36 pm by Jon Cunningham | Last modified 4/27/2013 5:18 am by Jon Cunningham | 2318 views | 4 replies |
Jon CunninghamBeta Tester
Hi Guys I have a strange issue with file uploads.
I have 5 upload fields.
User image
Gallery Image 1, Gallery Image 2, Gallery Image 3, Gallery Image 4.
If I upload User Image it stores in the database. If I then upload any gallery images, they store in the database but the upload process removes the User image. If I then add the User image again, the Gallery images are removed from the database.
I have attached my page for reference if anyone could take a look at this for me.
Much appreciated,
Regards
Jonathon
This page is not actually uploading any images, it is only sending a file name to the database.
for each file field, add a hidden form element, set the value of the hidden form element to use the coresponding column from the recordset for that image field.
then add the WebAssist -> File Manipulation -> Uplaod file server behavior.
for the default file name select the coresponding hidden form element.
repeat this for each file field.
Each file upload behavior will create a new binding group named WA Uploaded File (<field field name>), each of these binding groups will have a server file name binding.
in the update record behavior, you need to bind each image column to the corresponding server file name binding.
Hi Jason, I remember now from previous tutorials about the hidden field. I did remember about Server File Name.
Many thanks again
Jonathon
I have followed your instructions and this is the out come:
If i upload all of the following in one and submit
User image
All images upload.
If i then change User image and update the user image updates and
are removed
Again i have attached my page as an attachment.
Many thanks in advance
Jonathon
Solved
I found the issue with the file uploads.
The Default file name was being written as :
'DefaultFileName' => "".((isset($_POST["gallery4Upload"]))?$_POST["gallery1Upload"]:"") ."",
replaced with :
'DefaultFileName' => "".($row_SecurityAssistusers["UserGalleryImage1"]) ."",
Now all works well.
regards
Jonathon
