Have built the security pages on blank php pages with the help of your wizard only, no manual interference. Then if I try to login or enter forgot password page I get the attached error even though the page exists. What should I look for? 2nd questio
Thread begun 4/25/2013 8:01 pm by rolf358571 | Last modified 4/29/2013 6:48 am by Jason Byrnes | 4118 views | 5 replies |
rolf358571
Have built the security pages on blank php pages with the help of your wizard only, no manual interference. Then if I try to login or enter forgot password page I get the attached error even though the page exists. What should I look for? 2nd question: whe
When I entered the forgotten password page and submitted my email address, I did get the email with the information so the database connection works.
rolf358571
Answer to your private message.
looking at the code for the login page, dreamweaver is set to use site relative links.
this causes DW to use the virtual() function for attaching helper file:
<?php virtual('/Connections/Bombase.php'); ?>
the virtual function is supported on only a small number of PHP servers, and will cause other issues even when it is supported.
in your site definition, there is an option to "Create Links Relative To:"
change this from Site to Document, this will cause DW to use the require_once() function instead of virtual() for attaching helper files.
it is the use of the virtual function that is causing the problem.
rolf358571
Jason. I have done the changes and set it to relative to documents but it did not help. I have since opened the page, detached from the template to see if the problem was there but it wasn't. Then removed the E-cart server behavior and now the page works. So the problem is with E-cart. Dreamweaver reports the following when in design view: "An unknown error occurred when discovering dynamically related files"
If I then open it in live view I get a blank page and when I look at the code, there is only the html tag and no code.
looking at the login page, there are still instances of the virtual function in place.
lines 7 - 12:
<?php virtual
("/webassist/form_validations/wavt_scripts_php.php"); ?>
<?php virtual
("/webassist/form_validations/wavt_validatedform_php.php"); ?>
require_once('../Connections/Bombase.php'); ?>
<?php virtual
"/webassist/security_assist/helper_php.php" ); ?>
require_once( "../webassist/security_assist/helper_php.php" ); ?>
I changed that to:
<?php require_once("../webassist/form_validations/wavt_scripts_php.php"); ?>
require_once("../webassist/form_validations/wavt_validatedform_php.php"); ?>
to get the login page working.
the pages will need to be recreated after changing the site preferences to use Document relative links instead of site relative links.
