Search results wrong from DataAssist Search Wizard
Thread begun 4/25/2013 7:02 pm by mrs | Last modified 4/26/2013 7:03 am by Jason Byrnes | 1873 views | 3 replies |
mrs
I have run the DataAssist search wizard from the menu WebAssist/Database/DataAssist Search Wizard, and the wizard seemed to have worked fine, but the results page is displaying ALL records within my DB table no matter what I search for.
What has happened? Pages attached.
Thanks.
CraigRBeta Tester
no pages attached ?!
mrs
Right, I have just realised that I have applied the search wizard to the search page rather than the results page!!! DOH
So, I have now tried to apply the wizard to the results page and am now getting a error from the search results page. Prior to running the wizard, I did test the page to make sure that the page populated with content, and all was OK. Now, either from a search or directly typing the address in, I am getting the following error:
Fatal error: Call to undefined function setQueryBuilderSource() in /Users/matthewstuart/Sites/ktc/forum_search_results.php on line 124
I have added the pages again and removed the previous versions I uploaded earlier.
move the search code at lines 188 - 228:
<?php require_once("webassist/database_management/wada_search.php"); ?>
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: WADAtbl_forumPOSTS;
//Searchpage: forum_search_box.php;
//Form: searchform;
$WADbSearch1_DefaultWhere "";
if (!
session_id()) session_start();
if ((isset(
$_POST["WADbSearch1"])) && ($_POST["WADbSearch1"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
$KeyArr0 = array("fld_fID""fld_fHEADING""fld_fCTNT""fld_fCAP1""fld_fCAP2""fld_fCAP3""fld_fCAP4""fld_fCAP5""UserFirstName""UserLastName""UserScreenName");
//comparison list additions
$WADbSearch1->keywordComparison($KeyArr0,"".((isset($_POST["searchbox"]))?$_POST["searchbox"]:"")  ."","AND","Includes",",%20","%20","%22","%22",0);
//save the query in a session variable
if (== 1) {
$_SESSION["WADbSearch1_forum_search_results"]=$WADbSearch1->whereClause;
else     {
//get the filter definition from a session variable
if (== 1)     {
    if (isset(
$_SESSION["WADbSearch1_forum_search_results"]) && $_SESSION["WADbSearch1_forum_search_results"] != "")     {
$WADbSearch1->whereClause $_SESSION["WADbSearch1_forum_search_results"];
    else     {
$WADbSearch1->whereClause $WADbSearch1_DefaultWhere;
  else     {
$WADbSearch1->whereClause str_replace("\\''""''"$WADbSearch1->whereClause);
$WADbSearch1whereClause '';
to line 20 so it is before the recordset.
