problems
Thread begun 4/25/2013 7:12 am by QuiruNet | Last modified 4/26/2013 6:35 am by Jason Byrnes | 4552 views | 13 replies |
QuiruNet
problems
since I bought this product I could not work with him for the errors, y can see all then in the next links:
http://www.viajestambre.es/mailing/admin_pm/
PHP Notice: Undefined variable: DigitalGoods in C:\Inetpub\vhosts\viajestambre.es\httpdocs\mailing\webassist\plugins\main_menu\menu.php on line 163 PHP Warning: mysql_free_result() expects parameter 1 to be resource, null given in C:\Inetpub\vhosts\viajestambre.es\httpdocs\mailing\webassist\plugins\main_menu\menu.php on line 163
I did not touch any of the code, just did what the instructions told me. You can not put the audience ... etc. ... etc. ..
QuiruNet
i updated the webassist\plugins\main_menu\menu.php and admin_pm\audiences.php to correct the issue, i have also logged the problem in our bug base to be corrected in a future version.
QuiruNet
audience filters
The thing is the audience filters doesn't wordk too, can you try it...
Looking at the page source, the source code has double spacing in it. I can see this double spacing also in the Javascriot files which is causing errors in the scripts.
this can happen with some FTP Programs when transferring from a Windows System to a Unix server due to the differences in line break characters used by those 2 OS's.
In your FTP Client make sure the transfer mode is set to ASCII, this can happen when the Binary transfer mode is used.
you will re upload the solution pack files using the ASII transfer mode.
QuiruNet
information
how i fix it?
you will need to re upload the solution pack files using the ASII transfer mode.
QuiruNet
and where i can finde de solution pack?
By solution pack, i mean the Files for the Power Messenger Solution pack.
The Power Messenger files that you downloaded.
basically, i am saying that the original upload of the power Messenger files did not transfer correctly. so you need to re upload them, this tile make sure the FTP program you use is set to use the ASCII Transfer method.
