Missing Menu Lighting Bolt
Thread begun 4/24/2013 10:19 am by Jon Cunningham | Last modified 4/24/2013 12:12 pm by Jason Byrnes | 728 views | 1 replies |
Jon CunninghamBeta Tester
Please could you tel me if this is correct.
When running SA and then going into `Configuring Form Settings` and choosing menu for one of my fields. The menu lighting bolt is missing from the UI to the left of the UI.
When running DA and `Configuring Form Settings` and choosing menu for one of my fields, I then follow on and configure the menu.
Kind regards
Jonathon
The security assist wizard does not have the ability to create dynamic menus in the wizard, you will need to create the recordset after the pages are created and populate the menu using the recordset.
this is only available in the Data Assist wizard.
