Update Page layout CSS
Thread begun 4/24/2013 7:58 am by john70964 | Last modified 4/25/2013 1:15 pm by john70964 | 3777 views | 9 replies |
john70964
Hello
I have an update page where the Description Name is above the item box is there a method where I can have these on the same line
similar to a table please?
Many thanks
John
<div class="lineGroup"> <label for="RecNo" class="sublabel" > RecNo:</label>
<div class="errorGroup">
<span>
<input id="RecNo" name="RecNo" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("updateboats","RecNo"):"".$row_WADAboats["RecNo"]."")); ?>" class="formTextfield_Medium" tabindex="2" />
</span>
</div>
</div>
<div class="lineGroup"> <label for="Manufacturer" class="sublabel" > Manufacturer:</label>
<span>
<input id="Manufacturer" name="Manufacturer" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("updateboats","Manufacturer"):"".$row_WADAboats["Manufacturer"]."")); ?>" class="formTextfield_Large" tabindex="3" />
</span>
</div>
the default unstlyed form does not have any CSS Applied to it.
you have 2 options:
1) Create a form layout using CSS Form Builder that has the layout you wish to use, save it as a preset, and select that as as the form design in the Data Brodge wizard.
2) Add css to unstyled form to give it tje look you want, for example to move the labels, and elements onto the same line, you need to create a style to add width to the line group, and float and width to the label and elements:
.lineGroup {
overflow: hidden;
width: 400px;
.sublabel {
float: left;
width: 200px;
.errorGroup {
float: left;
width: 200px;
john70964
Thanks Jason
I already have a Dataassist preset which I used
The preset shows the update fields at the width and layout required but the dont appear on the final page like that.
Please see the images
Thank you
john70964
I just noticed the unpublished Update page looks OK but does not publish like that.
Please see attached image
Thank you
john70964
there is no style associated to this form. It is using the fd_basic_default style which does not fdefine any css.
add the following css:
.lineGroup {
overflow: hidden;
width: 400px;
.sublabel {
float: left;
width: 200px;
.errorGroup {
float: left;
width: 200px;
to put the labels on the same row as the elements.
john70964
Thanks Jason
Sorry to say I dont know where to place the lines of code.
Would you please say where to place the lines.
add a style tag in the head of the page:
<style type="text/css">
.lineGroup {
overflow: hidden;
width: 400px;
.sublabel {
float: left;
width: 200px;
.errorGroup {
float: left;
width: 200px;
</style>
john70964
Very many thanks Jason
Most helpful I begin to see the CSS light!
