Dreamweaver CS6 not working well after Design Extender Installation
Thread begun 4/24/2013 2:41 am by ori382079 | Last modified 4/24/2013 11:43 am by Jason Byrnes | 3013 views | 3 replies |
ori382079
Just installed Design Extender and my dreamwever CS6 crashes frequently. Whenever I log into dreamweaver, I keep getting the follwing Messeger: The Following Javascript error(s) occurred:
"At line 24 of the file "c;/users/annyka/Appdata/Roaming/Adobe/Dreamweaver CS6/ en_US/Configuration/Floaters/WA_Memento.js". document.reminders/WP.document has no properties."
Hi Have you tried resettting your workspace. (see my attached screenshot, btw CustomX is a workspace I created myself but you can reset any of the other workspaces you use)...
Also try deleting the cache files in the dreamweaver usually called something like 'WinFileCache_1-E4854B7D.dat'
they are located in: (Winsows 7) Also you may need to shows all for Folders & Files from the Control Panel
Computer -> Local Disk (C:) -> Users -> YourName -> AppData -> Roaming -> Adobe -> Dreamweaver CS6 -> en_US -> Configuration
Chris
ori382079
Thanks, but this does not help, I had deleted the WinFileCache_1-E4854B7D.dat before logging this problem and the workspace seems not to resolve the problem.
Dreamweaver is hanging after on for a short period which wasn't before I installed the Design Extender. By the way I had the Databridge before Design Extender, could the sequence of installation have anything to do with this problem? I do still get the same error message.
What other extensions besides design Extender are installed?
the only extensions that we offer that are compatible with DW CS6 are :
eCart 5
free tools
design Extender
Data Bridge.
these products have all had the memento panel removed.
