In the Double Opt Method, does the "login_fail" page have any PHP code? No problem yet, but I can't tell if something missing.
Thread begun 4/23/2013 2:20 pm by beaded | Last modified 5/03/2013 3:11 pm by beaded | 1065 views | 2 replies |
beaded
I don't know if I inadvertently "mangled" the page, but it has no PHP code, only the "login failed" message.
So, my question is, does the security assist wizard, as used in the Double Opt In tutorial, produce a "login_fail" page that has PHP code or does NOT have any PHP code and links.
No, the login failure page does not need to have any PHP code on it, only a message that login has failed, you can add a link back to the login page if you like.
beaded
Thanks!
