Removing Address Bubbles ma
Thread begun 4/23/2013 9:15 am by Jon Cunningham | Last modified 4/24/2013 2:49 pm by Jon Cunningham | 1943 views | 4 replies |
Jon CunninghamBeta Tester
I have a Pro map with a width of 280px. The address bubble gets cut off and makes the map look a little crap to be honest. I have searched the forums for an answer to remove the address bubble but none of the solutions work.
I am running the latest releases of Data Bridge and Design Extender.
If anyone can offer a solution I would be grateful for the help.
Kind regards
Jonathon
In the map js file, find the following line:
// open info window for default address
if (isDefault) {
infowindow.open(map1,marker);
map1.setCenter(point);
and comment the infowindow.open line:
if (isDefault) {
//infowindow.open(map1,marker);
NOTE: the map1 reference may have a different number
This is the content of my wagmp_maps.js file
/*wagmp_onload*/
if(window.wagmp_map_1) wagmp_map_1();
Jonathon
look for a file named wagmp_map_1.php
That worked great thank you.
You are a star.
Jonathon
