How to use Framework Theme with eCart 5
I have already built a cart page using a theme. When I run the wizard it only shows my Dreamweaver templates and no themes. When I run the wizard there are tons of pop up errors all saying "The template that this document is based on does not allow changes outside the <html> tag. The changes you made will be discarded". Although there is a region set for the body (which I select). So do I run the wizard with no template then apply the theme to each page or what? Thanks in advance
