Dataassist, insert record, digital file pro
Thread begun 4/22/2013 11:47 am by Patrice | Last modified 4/22/2013 3:00 pm by Christopher West | 1899 views | 5 replies |
PatriceWebAssist
I've tried to find the answer in the forum but failing. I have two digital file pro fields in a DA insert page. Both are identified uniquely. The form is set to multi post.
method="post" enctype="multipart/form-data" name="Insert_Cool_Default"
The first uploader works ok. The second one does not.
Any pointers, most appreciated.
PatriceWebAssist
Hi there have you tried for the second upload server behaviour for the trigger, setting that trigger to "Any Upload Successful"
Chris
PatriceWebAssist
I chose the when "insert button" pressed...but I'll give your idea a try. Thanks for the suggestion.
PatriceWebAssist
Brilliant! That did it! Thank you so much for taking the time and sharing the solution. :-)
Your welcome. Glad you have sorted it.
