Internal Server Error while sending a loop of emails
Thread began 4/22/2013 8:39 am by edu311178 | Last modified 4/23/2013 7:21 am by Jason Byrnes | 3092 views | 3 replies |
edu311178
Hello, good afternoon.
We have encountered an error that behaves as follows:
Once we send emails (several or a lot, it doesn't matter the amount) the server sends them rightly.
After this, it's supposed to redirect to a php page (line 306 within the php file "fss_mailing_enviar.php" which we have attached):
header("Location: ".$GoToPage);
where $GoToPage stores the value "css_mailing_enviar_ok_resumen.php".
However, after several seconds, we get and error window with a 500 error (Internal Server Error, like the one you can view int attached image within this email). So the problem is not connected with sending emails but with redirecting to this page, due to an error connected with the server.
We'll appreciate you help.
Thanks in advance.
the 500 internal server error is impossible to troubleshoot.
it is a generic error message that only means "an error has occurred"
we may be able to tell the real error for troubleshooting by turning error reporting on. add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
edu311178
Good morning.
Thanks a lot for your quick response.
We've already wrote the lines you specified, in both remote server and our local server. Both behaviours are like follows:
REMOTE SERVER (the one we want to work properly):
1) Throws this simple warning:
Deprecated: Function ereg() is deprecated in C:\xampp\htdocs\fss\admin\fss_menu.php on line 57
2) Starts to send emails but suddenly the "Internal server error" page appears. However emails are still being sent correctly after this.
LOCAL SERVER (not configured to end emails so more warnings expected. We're also using the PHP Yii framework in debug mode):
1) Throws these warnings:
( ! ) Notice: Undefined index: MM_UserGroup in C:\xampp\htdocs\fss\admin\fss_mailing_enviar.php on line 41
Call Stack
# Time Memory Function Location
1 0.0015 203624 {main}( ) ..\fss_mailing_enviar.php:0
( ! ) Warning: Illegal string offset '[nombre]' in C:\xampp\htdocs\fss\webassist\email\waue_fss_mailing_enviar_2.php on line 50
Call Stack
2 1.0130 397512 include( 'C:\xampp\htdocs\fss\webassist\email\waue_fss_mailing_enviar_2.php' ) ..\fss_mailing_enviar.php:279
( ! ) Notice: Undefined index: [nombre] in C:\xampp\htdocs\fss\webassist\email\waue_fss_mailing_enviar_2.php on line 50
Call Stack
2 2.4059 405640 include( 'C:\xampp\htdocs\fss\webassist\email\waue_fss_mailing_enviar_2.php' ) ..\fss_mailing_enviar.php:279
Call Stack
2 3.6480 406856 include( 'C:\xampp\htdocs\fss\webassist\email\waue_fss_mailing_enviar_2.php' ) ..\fss_mailing_enviar.php:279
( ! ) Warning: session_start(): Cannot send session cookie - headers already sent by (output started at C:\xampp\htdocs\fss\webassist\email\waue_fss_mailing_enviar_2.php:50) in C:\xampp\htdocs\fss\webassist\email\mail_php.php on line 289
Call Stack
3 3.6499 408840 WAUE_SendMail( ) ..\waue_fss_mailing_enviar_2.php:97
4 3.6507 410888 session_start ( ) ..\mail_php.php:289
( ! ) Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at C:\xampp\htdocs\fss\webassist\email\waue_fss_mailing_enviar_2.php:50) in C:\xampp\htdocs\fss\webassist\email\mail_php.php on line 289
Call Stack
Call Stack
2 4.8276 407272 include( 'C:\xampp\htdocs\fss\webassist\email\waue_fss_mailing_enviar_2.php' ) ..\fss_mailing_enviar.php:279
Call Stack
3 4.8314 409176 WAUE_SendMail( ) ..\waue_fss_mailing_enviar_2.php:97
4 4.8319 411224 session_start ( ) ..\mail_php.php:289
Call Stack
( ! ) Notice: Undefined index: waue_fss_mailing_enviar_2_Status in C:\xampp\htdocs\fss\admin\fss_mailing_enviar.php on line 301
Call Stack
( ! ) Notice: Undefined index: waue_fss_mailing_enviar_2_Index in C:\xampp\htdocs\fss\admin\fss_mailing_enviar.php on line 302
Call Stack
( ! ) Notice: Undefined index: waue_fss_mailing_enviar_2_From in C:\xampp\htdocs\fss\admin\fss_mailing_enviar.php on line 303
Call Stack
( ! ) Notice: Undefined index: waue_fss_mailing_enviar_2_To in C:\xampp\htdocs\fss\admin\fss_mailing_enviar.php on line 304
Call Stack
( ! ) Notice: Undefined index: waue_fss_mailing_enviar_2_Subject in C:\xampp\htdocs\fss\admin\fss_mailing_enviar.php on line 305
Call Stack
( ! ) Notice: Undefined index: waue_fss_mailing_enviar_2_Body in C:\xampp\htdocs\fss\admin\fss_mailing_enviar.php on line 306
Call Stack
( ! ) Notice: Undefined index: waue_fss_mailing_enviar_2_Header in C:\xampp\htdocs\fss\admin\fss_mailing_enviar.php on line 307
Call Stack
( ! ) Notice: Undefined index: waue_fss_mailing_enviar_2_Log in C:\xampp\htdocs\fss\admin\fss_mailing_enviar.php on line 308
Call Stack
( ! ) Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\fss\webassist\email\waue_fss_mailing_enviar_2.php:50) in C:\xampp\htdocs\fss\admin\fss_mailing_enviar.php on line 313
Call Stack
2 5.0470 381000 header ( ) ..\fss_mailing_enviar.php:313
Sorry for the long text but better to show here each one detailed.
We think that the only important warning which could probably interrupts/interferes with the redirection to the succes page is the one about "Cannot modify header information - headers already sent by...". We tried to use "ob_start()" and "ob_end_flush()" but nothing seemed to change on the remote server, but it worked on the local one!.
In summary, in the remote server, emails are sent correctly (which is great) but still we get the "Internal error server" page instead of the succes one (redirection to "fss_mailing_enviar_ok_prueba").
Hope you can help us. Greetings and thanks a lot.
I'm not woried ablut the local server since it wont be able to send emails anyway.
the headers already sent error is caused by the other errors.
the error:
will need to be corrected in the fss_menu.php on line 57. instead of using the ereg function, it should use the preg_match function.
for the other errors, delete the webassist/mail/mailphp.php and mailformating.php files, then edit the universal email instance and click ok to have those files regenerated, make sure to upload the newer versions.
