Discount / coupon code & specific item/s in cart
Thread begun 4/22/2013 6:02 am by Art | Last modified 4/22/2013 12:42 pm by Art | 1369 views | 2 replies |
Art
How do I apply a discount (20%) to specific items (roughly 80 items) that get discounted if coupon code matches?
If they purchase more than one or multiples, the 20% is taken off the row total. There may be multiple rows/items. The problem I'm having is that I can get it to work on one but not the total of the row and not on multiple rows (parts) either.
To start, I think I need to add a trigger rather then testing for each individual product. In other words, instead of adding 80+ rules for each of the 80 items I would use a session or ecart binding to test? Correct?
What's the easiest way; can you point me in the right direction?
use the cart conditionalTotal command.
for the coupon calculation use a flat rate and enter:
$this->ConditionalTotal("TotalPrice", "CouponColumn", "1") * 0.20
this sample assumes the coupon column is named CouponColumn, and the value stored in this column be the add to cart is 1.
Art
Perfect
