Google ProMaps and Repeat Region
Thread begun 4/21/2013 4:23 pm by asnw0764437428 | Last modified 4/22/2013 9:57 am by Jason Byrnes | 1009 views | 1 replies |
asnw0764437428
Im creating a business directory and trying to add into each listing a map. I have read somewhere that you cannot add the promaps to the page in this way to create multiple instances each one showing a different address. Is this correct?
I have been using promaps for a number of years and this is the first time I have tried to implement promaps in this way. If it cannot be done, is there any possibility that this feature will be added in to any future updates as I do believe this would open up the possibilites when developing websites. Also the option to hide the address info window should at the very least by now have a tick box to select whether you want to show or hide the info window.
no, pro maps does not offer support for using it in a repeat region to show a map for each address.
as an alternative, you can show one map and include all of the address points, then in the repeat region, add links that will focus the map to the selected address:
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=87
I will log a feature request to add an option to hide the info window.
